Activity Forums Apple Final Cut Pro Legacy Resizing 16:9 sequqnce cut in 4:3
  • Resizing 16:9 sequqnce cut in 4:3
    Posted by Kevin on October 16, 2007 at 12:50 am
    Hi list,
    I have 16:9 anamorphic footage which I cut in error in a 4:3 sequence. Ultimately what I want want is to output in 16:9
    I thought buy creating a new sequence with anamorphic checked that I could copy and past the sequence and it would resize to 16:9 but appanrently it remembers it original settings and is further restretched.
    Would anyone be able to suggest a metchod where I can transpose my sequence from it 4:3 aspect ratio and so I can output to fullframe 16:9?
    Any enlightenment would be appreciated.
    Warmest,
    Kevin
    Kevin replied 18 years, 10 months ago 2 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    October 16, 2007 at 1:02 am
    Once on the proper time line, you will have to go under the motion tad and reset the settings.
  • Kevin
    October 16, 2007 at 1:44 am
    Thank you so much for your prompt response. OK, I have resized in a sequence that is 4:3 with anamorphic checked and it looks good. Yet when I export I get a 4:3 movie.
    Are there settings I need to change in the export to maintain the 16:9 image I’m viewing.
    On another note might I have gone stepped through the sequence, matched back to the original footage and rebuilt the project that way to maintain my 16:9 image.
    Again many thanks for your assistance. I hope I’m close.
    Warmest,
    Kevin
  • Kevin
    October 17, 2007 at 3:16 am
    I have noticed that when I export as an AVI that I do get a 16:9 image. However when I export as a self contain QT from the same sequence, I get a 4:3 image. At least a partial workaround but I’m still curious if anyone might be able to tell me how I can get a 16:9 QT our of FCP?
    Of further note, the 4:3 QT I get, when opened in Premiere (I know) that QT shows up as a 16:9 image also!
    I’d b very grateful if anyone could shed some illumination on the subject.
    Warmest,
    Kevin
