Activity Forums Adobe Premiere Pro resizing 1080p to 720p
  • resizing 1080p to 720p
    Posted by Willian Praniski on October 11, 2013 at 9:29 pm
    Hi, i shot some footage on full res (1080) just so i could get the hand held shot and stabilize in post and resize to 720p.
    this way i don’t lose much with the cropping i get stabilizing the shots in post. im just wondering if the best way to go is just drop the 1080p footage in a 720p timeline and resize it to fit the screen or theres a better way to do this?
    thanks
    Ivan Myles replied 12 years, 11 months ago 2 Members · 1 Reply
  • Ivan Myles
    October 12, 2013 at 1:53 am
    If you are using Warp Stabilizer in Premiere Pro, create a 1080p sequence as per the clip’s properties. Insert the footage into the timeline and apply Warp Stabilizer without scaling.
    Insert the 1080p sequence with the stablized footage into your 720p timeline as though it were a clip. For best quality, adjust the (x,y) position and scale% in the 1080p sequence (using the Warp scale control) until it fits properly in the 720p timeline.
