Activity Forums Apple Final Cut Pro Legacy Resize video in FCP
  • Resize video in FCP
    Posted by Vanessa Shaw on October 22, 2009 at 4:26 pm
    I am trying to create a sequence in FCP 6.0.6 using 4 video clips resized to fit side by side. These clips were shot in regular old mini DV – 720 x 480, 29.97,DV/DVCPRO NTSC.
    I want the clips to be resized to 25% so that they can play simultaneously side by side. When I do so, even after render, they are fuzzy.
    What’s the problem? The original video was crystal clear and sharp.
    THANKS!!!
    Rafael Amador replied 16 years, 10 months ago 5 Members · 12 Replies
  • 12 Replies
  • Tom Wolsky
    October 22, 2009 at 5:21 pm
    Are you looking at the rendered output on a video monitor?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Vanessa Shaw
    October 22, 2009 at 5:55 pm
    Thanks for your reply. I haven’t looked at it on a monitor, but when I export it and view it on my computer it still looks terribly pixelated. The final product will be projected via a DVD played from a computer, if that helps… That is, not for broadcast.
  • Nicole Haddock
    October 22, 2009 at 5:58 pm
    I answered this on another forum –
    https://forums.creativecow.net/thread/200/882910#882911
    Make sure the positioning on the Center point is in EXACT numbers, not decimals. I would also check your render settings in the RT tab in your sequence and that you’re rendering everything fully in the timeline.
  • Vanessa Shaw
    October 22, 2009 at 6:05 pm
    I wish it were that simple. I am using exact numbers, no decimal, and everything is rendering at full quality. thanks!
  • Shane Ross
    October 22, 2009 at 6:24 pm
    Set the Canvas to 100%…now what?
    But still, the COMPUTER MONITOR is not the best way to judge quality. External TV or Production monitor only.
    #2 Blurry Playback
    Shane’s Stock Answer #2: Blurry playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL BROADCAST MONITOR, OR AT LEAST A TV.
    The Canvas shows you what happens after the codec you are working with has been applied. The Viewer shows you the material in its native format. Once you drop the footage from the Viewer into the timeline, it inherits the attributes of the sequence. If it is a DV sequence, the footage will render out as DV.
    1. Disable overlays on the Canvas.
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline).
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or broadcast monitor routed thru your camera or deck.
    Shane
  • Nicole Haddock
    October 22, 2009 at 6:26 pm
    In your sequence, check the Sequence Settings/Video processing tab, and check that Motion Filtering Quality is set to Best. Also, check (I know you said it is, but I like double checking) Sequence/Render All/everything is checked for video.
    What’s the Compressor setting in your Sequence settings?
    In the sequence itself, check the RT tab on the upper left and make sure you’re on Safe RT, Playback Video Quality- High, Playback Frame Rate – Full.
    Assuming all that is set, in your Canvas window, are you looking at it 100%? Not 99 or some other weird number (50 and 25 not being weird)?
    If it looks bad in FCP still, and it looks bad on export, how exactly are you exporting your file? And once looking at it in QT, are you putting the video quality on “high quality” in the Movie Properties/video track area?
  • Nicole Haddock
    October 22, 2009 at 6:34 pm
    And here’s my dumb follow up question-
    What does ONE clip scaled down and tossed in your timeline look like? Just popped right in, no repositioning. Good or crap?
  • Vanessa Shaw
    October 22, 2009 at 7:28 pm
    One clip looks great! Why can’t it look that good with all 4??
  • Nicole Haddock
    October 22, 2009 at 7:39 pm
    We’re entering boggling territory, thus, let us start from the beginning.
    Let’s get the:
    System specs
    FCP specs
    Footage specs
    Sequence settings
    And a screen grab of how terrible it looks may also be helpful.
  • Vanessa Shaw
    October 22, 2009 at 9:11 pm
    OK.
    System: 2 x 2.8 GHz Quad Intel, Memory – 4 GB 800 MHz
    FCP: 6.0.6
    Footage: 720 x 480 DV/DVCPRO
    Sequence Settings: 720 x 480 NTSC DV (3:2), Pixel Aspect Ratio: NTSC – CCIR 601 DV(720×480), Field Dominance – Lower, Compressor – DV/DVCPRO-NTSC at 100% quality
    The footage is for a video artist’s installation, so it’s not so straight forward to look at (i.e. no faces or anything recognizable). So a screen grab wouldn’t tell you a lot… hope that makes sense.
    Thanks so much for all your help!
