Activity Forums Adobe After Effects resize the whole compositon
  • resize the whole compositon
    Posted by Yarin Manes on July 26, 2008 at 10:09 am
    hey,
    iv done a promo which should broadcast on web and my comp settings were pal and all layers/text/effects are designed by that size,anyway in this point after all the work is it possible to resize to smaller (web) aspect ratio without me needing to fix everything from begining?
    Alex Dinnin replied 18 years, 1 month ago 2 Members · 1 Reply
  • Alex Dinnin
    July 26, 2008 at 2:28 pm
    Hi Yarin,
    This is really easy to do.. All you need to do is, create a new composition with the new aspect ratio you require. (keyboard shortcut Ctrl – N)
    Then drag your Pal composition into your new smaller comp, and just scale it down to fit..
    hoep this helps
    Alex
