Activity Forums Adobe After Effects Resize Output
  • Resize Output
    Posted by Chip Hess on April 2, 2012 at 3:46 am
    I have created a custom size for a multi-monitor trade show display.
    Created 7680 X 1080. I need to output 1920 X 1080, squeezing the image.
    It is then unsqueezed by the show techs for proper display.
    The glitch is I set output to resize from 7680 X 1080 to 1920 X 1080,
    per the tech’s instructions. However when I render I am still getting
    the full size, rather than the specified 1920 X 1080.
    Thoughts …?
    Chip Hess replied 14 years, 5 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 2, 2012 at 3:59 am
    [Chip Hess] “I have created a custom size for a multi-monitor trade show display. Created 7680 X 1080. I need to output 1920 X 1080, squeezing the image. It is then unsqueezed by the show techs for proper display.”
    4:1. That’s some serious anamorphism. You should expect ugly stair-stepping on the displays on rounded shapes or diagonal lines.
    [Chip Hess] “The glitch is I set output to resize from 7680 X 1080 to 1920 X 1080, per the tech’s instructions. However when I render I am still getting the full size, rather than the specified 1920 X 1080.”
    How have you set the output to resize?
    I see two easy options:
    • Create a 1920×1080 comp. Drop your 7680×1080 comp within the 1920×1080 comp, then hit Ctrl-Alt-F on a PC (Cmd-Opt-F on a Mac) to transform the layer to the comp size.
    • Add the 7680×1080 comp to the render queue, then modify the output module. Check the Resize box, uncheck the maintain aspect ratio button, and manually enter 1920×1080 for the size.
    Walter Soyka
  • Chip Hess
    April 2, 2012 at 2:29 pm
    Regarding the squeeze, believe me I know.
    I have nothing to do with the presentation, just following specs given and handing off.
    Creating new comp and fitting layers was what I had to do.
    I could no get resize to work using settings below, no matter what.
