Activity Forums Adobe After Effects Resize masked image
  • Resize masked image
    Posted by Esky Ching on March 2, 2011 at 4:06 am
    Hello!
    I have rectangular masked an image in a comp, when I do right-click on Scale parameter -> Edit value, after resizing, for example, resize to 100% of the comp’s height, it uses the original height value of the image instead of the masked height value of the image, which makes my scaled image small than the comp.
    Although I can manually adjust the scale, but it takes a bit more time.
    Any way to resize by using masked image height?
    Esky Ching replied 15 years, 6 months ago 2 Members · 2 Replies
  • Michael Szalapski
    March 2, 2011 at 10:42 pm
    Not that I know of, but instead of masking, you could put it in a precomp and make that comp size, the size you want. Then you could resize the precomp in your main comp.
    However, it may be easier just to resize it manually.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Esky Ching
    March 3, 2011 at 1:48 am
    Thanks very much.
    It works very well with the precomp method.
    And it helps reposition the anchor point to the center as well.
