Activity Forums VEGAS Pro Resize from 1440x1080i to 1920x1080i
  • Resize from 1440x1080i to 1920x1080i
    Posted by Michael Denford on February 23, 2014 at 11:49 pm
    Good day,
    Just would like to ask if there is any benefit in resizing 1440x1080i video footage to 1920x1080i? I can imagine that quality may be affected.
    Also, is there any benefit in rendering Interlaced footage to Progressive?
    Many thanks guys.
    John Rofrano replied 12 years, 6 months ago 3 Members · 4 Replies
  • Mike Kujbida
    February 24, 2014 at 1:42 am
    There will be no quality hit as both are the same size, just with a different PAR (Pixel Aspect Ratio). The former has a PAR of 1.333 while the latter has a PAR of 1.0
    I regularly render my 1440×1080@60i projects to 1280×720@30p for YouTube use and don’t have any problems.
  • Michael Denford
    February 24, 2014 at 2:02 am
    That’s great regarding the ‘no loss’ of quality. Can I trouble you for the best project and render settings to create a Bluray compliant mpge2 file?
    I assume rendering from 1080i to 1080p is definitely the way to go. Would this be correct?
    Thanks for your help with this Mike.
  • Mike Kujbida
    February 24, 2014 at 12:23 pm
    Sorry Michael but I’ve never made a Blu ray disk and don’t want to send you down the wrong path. This topic has been discussed at length on the Cow Vegas forum so I recommend searching there for the answers. Look for posts by John Rofrano as he answers this question a lot and knows what he’s talking about.
  • John Rofrano
    March 2, 2014 at 1:57 pm
    [Michael Denford] “Can I trouble you for the best project and render settings to create a Bluray compliant mpge2 file? I assume rendering from 1080i to 1080p is definitely the way to go. Would this be correct?”
    Actually Blu-ray wants interlaced video for NTSC and PAL and only allows progressive for NTSC 24p. If you are shooting HDV then I would use MainConcept MPEG-2 with Blu-ray 1440×1080-60i, 25 Mbps video stream template. This matches your source footage exactly. You could also use the Blu-ray 1920×1080-60i, 25 Mbps video stream template as well.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
