Activity Forums Adobe Premiere Pro Resize-Effekt in Premiere 6.5
  • Resize-Effekt in Premiere 6.5
    Posted by Kilsen on April 22, 2005 at 3:58 pm
    I want to resize my film, but the once effekt I found cuts the the parts on the top and bottom and don’t push it. So how can I make a simple letterbox in Premerie 6.5?
    thanks for reading
    Dan Plonsker replied 21 years, 5 months ago 3 Members · 4 Replies
  • Steven L. gotz
    April 22, 2005 at 4:45 pm
    A simple letterbox is usually done using the titler. There is a template, under Mattes, called Letterbox. Just drop it on your top track and make it’s duration long enough to cover your timeline.
  • Kilsen
    April 22, 2005 at 6:20 pm
    But the Problem is that it don’t push the image together. it only covers. it should be an effect like resize in avid express.
  • Steven L. gotz
    April 22, 2005 at 6:54 pm
    I misunderstood the question.
    I suggest that you use a virtual clip and apply the Transform effect. Then set the vertical scale to 75%
  • Dan Plonsker
    April 23, 2005 at 9:21 am
    Use Motion. Center the clip and use the Zoom to resize.
