Activity Forums Adobe After Effects Expressions Resize comp to match layer exactly
  • Resize comp to match layer exactly
    Posted by Jamie Wood on February 6, 2013 at 12:00 pm
    Hi
    I have a huge comp (11k x 21k) that needs to be rendered out in 720×1280 sections. I have positioned solids in a grid to match the areas that need to be rendered. Does anyone know of an expression or script that will resize and reposition the huge comp to match one of these solid layers? The grid is unfortunately not regular and the borders at the bottom/top are different to the sides, meaning I can’t use the layer splitter script. I’ve looked at Autocrop and some random bits of script that I’ve found online but nothing has worked as I need it to thus far.
    Cheers
    Jamie Wood replied 13 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
