Activity Forums Adobe After Effects Expressions Resize a layer according to the image size
  • Resize a layer according to the image size
    Posted by Jeff Horowitz on May 8, 2014 at 7:42 pm
    So I have two layers: 1) is a solid. 2) is an image.
    I want to add an expression to the scale property of the solid to tell it to resize according to the size of the image.
    The whole comp is 1920×1080
    The solid is 1920×1080 & scaled down to 78.0,80.0%
    The image.png is 1920×1080 & scaled down to 75.0,75.0%
    Here’s the example:
    Now, if I replace that 1920×1080 image with an image that is 400×533, I want the white solid to resize to fit the dimensions of the new image.
    Here’s the example:
    Jeff Horowitz replied 12 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 8, 2014 at 9:09 pm
    This assumes that the solid is directly below the image. Adjust the variable “border” to adjust the border width.
    L = thisComp.layer(index-1);
    border = 20;
    w = L.width*L.scale[0]/100 + border*2;
    h = L.height*L.scale[1]/100 + border*2;
    [w*100/width,h*100/height]
    Dan
  • Jeff Horowitz
    May 9, 2014 at 12:04 am
    That worked perfectly…thanks
    JAH
