Activity › Forums › Avid Media Composer › resetting values in the Effects editor…
  • Grinner Hester
    December 22, 2005 at 5:01 pm
    I hope I’m not misunderstanding…
    just click on the slider you wanna change and type in the value you want.
  • Alex Udell
    December 22, 2005 at 5:18 pm
    Where do I click?
    On the value or on the slider?
    Thx…
    Alex
  • Lucas Merino
    I would also like to know this. Other apps have a “reset” button in the effects console that sets the effect parameters to default values. This is much faster than having to remove the effect and re-apply it just to get default values.
  • Alex Udell
    December 22, 2005 at 7:03 pm
    OK…
    so click the slider and type a value got it…
    Perhaps a good rule of thumb is to drag the default settings to a bin…
    so you can just redrop it on a clip if you want quick reset…
    Alex
  • Grinner Hester
    December 22, 2005 at 7:14 pm
    you can always just remove the effect and reapply it.
  • Alex Udell
    December 22, 2005 at 10:32 pm
    not as easy to do with PSD’s….but I get your point…
    thanks :-)’r
    Al-x
  • Les Kaye
    December 23, 2005 at 12:03 am
    Do you mean tabbing between parameters and simply typing in a value, which is in there?
  • Don Days
    December 23, 2005 at 3:15 am
    You can ALT-Click the button parameter button (on the right side of the effect editor) and that will reset just that parameter to default values. You can also save the effect and drag the saved effect into any of the parameters on any new effects you apply. Example, lets say you have a 3D warp effect where you have the image cropped a ceratin way you like…save this effect…then if you apply another 3D warp effect to a different clip you can drap the saved effect right into the crop parameter area and it will crop the new clip just like the first.
    Hope that helps
  • Alex Udell
    December 23, 2005 at 10:42 am
    Hi Don…
    Thx…
    it was the ALT Drag on matte key fx to save the paramters w/o the source that I was having trouble with…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    See My Current Reel
    visit the combustion exchange ftp
  • Lucas Merino
    December 23, 2005 at 5:14 pm
    I would like to thank you for that alt-click idea too
    thanks 😉
