Activity Forums Adobe After Effects “Resetting time code” for quicktime files
  • “Resetting time code” for quicktime files
    Posted by Henrik Bach christensen on January 27, 2006 at 3:26 pm
    Does anyone know if there’s a way of resetting the time code on quicktime files?
    Let me explain:
    I have a 10bit 4:2:2 (aja codec) file, that has been captured elsewhere from DigiBeta. To ease the load on my computer, I’ve reencoded it to Microsoft DV using canopus procoder 2, and am going to edit it in Premiere Pro 1.5. The time code in the DV file starts from zero, whereas the 10 bit file starts from the media timecode from the Beta tape. In the past I’ve solved this by dropping it into a sequence i Final Cut and exporting it to a self contained quicktime 10bit 4:2:2 movie, thus “resetting” the time code. This is however very time consuming, and I’m thinking there’s got to be an easier way of just resetting the header of the 10bit 4:2:2 file or something. Can anyone help here?
    Henrik
    Adolfo Rozenfeld replied 20 years, 7 months ago 2 Members · 1 Reply
  • Adolfo Rozenfeld
    January 27, 2006 at 8:10 pm
    Open the files in Quicktime Player 7 Pro.
    Go to Window > Show movie properties.
    Select the the Timecode track and delete it.
    Save the file.
    To tell you the truth, this is not very related to AE, because AE doesn’t work with the source’s embedded timecode.
    All the best!
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
