Activity Forums Apple Final Cut Pro Legacy “Resetting time code” for quicktime files
  • “Resetting time code” for quicktime files
    Posted by Henrik Bach christensen on January 27, 2006 at 3:30 pm
    Does anyone know if there’s a way of resetting the time code on quicktime files?
    Let me explain:
    I have a 10bit 4:2:2 (aja codec) file, that has been captured elsewhere from DigiBeta. To ease the load on my computer, I’ve reencoded it to Microsoft DV using canopus procoder 2, and am going to edit it in Premiere Pro 1.5. The time code in the DV file starts from zero, whereas the 10 bit file starts from the media timecode from the Beta tape. In the past I’ve solved this by dropping it into a sequence i Final Cut and exporting it to a self contained quicktime 10bit 4:2:2 movie, thus “resetting” the time code. This is however very time consuming, and I’m thinking there’s got to be an easier way of just resetting the header of the 10bit 4:2:2 file or something. Can anyone help here?
    Henrik
    Tom Wolsky replied 20 years, 8 months ago 2 Members · 2 Replies
  • Tom Wolsky
    January 27, 2006 at 4:34 pm
    In FCP you can select the clip and use Modify>Timecode. This will change the timecode track on the QT media file. It’s a destructive function.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Tom Wolsky
    January 27, 2006 at 7:13 pm
    You can set it to either drop or NDF.
    All the best,
    Tom
