Activity Forums Apple Final Cut Pro Legacy Resetting the default sequence settings… instant correctness without adustment
  • Resetting the default sequence settings… instant correctness without adustment
    Posted by Travis Roesler on October 22, 2012 at 8:53 pm
    I need to copy a ton of clips to their own sequences. It will be incredibly annoying to have to change the sequence settings every single time. Is there any possible way that I can just set the sequence settings so that every time I click “add new sequence”, everything is correct?
    That would be amazing. Thanks in advance for your time.
    Travis Roesler replied 13 years, 10 months ago 5 Members · 13 Replies
  • 13 Replies
  • Shane Ross
    October 22, 2012 at 9:39 pm
    Yes. Go into the EASY SETUPS…choose the one that matches what you are doing. Or modify one to match…and have that selected. Then every new sequence will have those settings.
    Shane
    Little Frog Post
  • Travis Roesler
    October 23, 2012 at 4:24 am
    Hey Shane,
    Thanks for the help man! Unfortunately, I went into easy setups, and nothing seems to match my currect sequence settings. When I hit command 0 to pull up the sequence settings, it says HD 1440×1080… nowhere in the entire “easy setup” list is that option given. I don’t know what to pick and I dont want to screw up my video :-/
  • Shane Ross
    October 23, 2012 at 4:25 am
    Look at the HDV settings. They are 1440×1080. There’s also a ProRes 1440×1080 setting, for HDV captured as ProRes. You don’t have those?
    Shane
    Little Frog Post
  • Travis Roesler
    October 23, 2012 at 4:37 am
    I uploaded a couple of images for ya so you can see what the heck im dealing with here.
  • Shane Ross
    October 23, 2012 at 7:20 am
    I don’t see them.
    You should have HDV 1080i60…and i50, I’m not sure what frame rate you are working with. 1440×1080 is an HDV frame size.
    Shane
    Little Frog Post
  • Joseph Owens
    October 23, 2012 at 4:29 pm
    Why not try dropping a clip onto a sequence, accept the Apple dialog to change the sequence settings to match the media… note the settings that Apple creates, and then use that data to create your own Easy Setup?
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Travis Roesler
    October 23, 2012 at 5:24 pm
    I was doing that, but when you have 200 sequences to make, the keystrokes add up. The problem that I’m having is that after I accept the dialogue and look at the settings, I’m not able to see an identical option in the easy set up.
    There should be some type of auto detect easy set-up, or “copy sequence settings”… I’m mad that there isnt.
  • Brad Elliott
    October 24, 2012 at 3:24 pm
    Wouldn’t this work?
    Create a sequence with the proper settings and remove any clips etc.
    Duplicate
    rename
    paste new content
    Even with easy set-up you will still have to name the sequence and paste the content
  • Nick Meyers
    October 24, 2012 at 10:58 pm
    i think most people are suggesting going beyond the Easy Setup and creating your own sequence preset
    this would be done in your A/V settings (under the FCP menu)
    i have another solution.
    put ALL the clips into one sequence.
    duplicate the sequence (not absolutely necessary, but wont hurt either)
    now go through your sequence, select each clip and NEST it (optionC)
    one cool thing about this is that the clip name will automatically be the nest name, saving you the chore of naming each new sequence after the clip.
    nick
  • Travis Roesler
    October 25, 2012 at 5:16 pm
    That’s brilliant… and by brilliant, I mean completely obvious but yea… why the hell didn’t I think to just duplicate the same sequence over and over.
    Good call man, thanks!
