Activity Forums Adobe Illustrator reset size of foto
  • reset size of foto
    Posted by Gunnar Kordestani on December 29, 2009 at 9:11 am
    hi there,
    is there a way to rest a foto back to it’s original size in Illustrator?
    If you go via >object >transform >scale it starts where u are at that point. So if any change of scale has done yet one cannot say what the original scale was.
    thks …Gunnar
    Mike Gondek replied 16 years, 8 months ago 2 Members · 1 Reply
  • Mike Gondek
    December 29, 2009 at 5:59 pm
    GOOD QUESTION! Wish they had an easier way to do this simple task. Here is the solution:
    Select image > links palette flyout menu > placement options > preserve >> file dimensions
    I have not found a solution to remove other transforms (eg: rotation, skew), except using the effect >> distort & transform >> transform. This effect is much more useful than it appears, and have used this as a solution on numerous jobs.
