Activity Forums Maxon Cinema 4D Reset interface color scheme
  • Reset interface color scheme
    Posted by Gabriel Vallecillo on February 20, 2018 at 10:03 pm
    Hi, I did something stupid and messed up the color scheme of the interface and need to get back to default.
    Any idea how to fix this?
    esegabbo
    \”Los límites de mi lenguaje son los límites de mi mundo\” / Wittgenstein
    Gabriel Vallecillo replied 8 years, 6 months ago 2 Members · 2 Replies
  • Jim Scott
    February 20, 2018 at 10:56 pm
    From the help files:
    Scheme Colors
    If you always thought green text on a pink background was the ideal color combination then you can use these parameters to make your dreams come true. Here you can define the color of just about any GUI element in Cinema 4D. Colors can be saved to individual schemes (Interface tab).
    You should however make sure that the colors you select result in legible menus, etc. In the worst case you can make Cinema 4D “unusable” if you select colors that result in menus that cannot be read. If this should happen simply delete the Cinema 4D.prf and *.col files (e.g., “dark.col” for the dark color scheme) in your user directory’s “prefs” folder. Cinema 4D will then restart with the default color scheme.
  • Gabriel Vallecillo
    February 21, 2018 at 3:56 pm
    “simply delete the Cinema 4D.prf and *.col files (e.g., “dark.col” for the dark color scheme) in your user directory’s “prefs” folder. Cinema 4D will then restart with the default color scheme.”
    esegabbo
