Activity Forums Adobe Encore DVD Reset Chapter Markers
  • Reset Chapter Markers
    Posted by Paul Benson on July 22, 2009 at 4:48 pm
    Using the CS4 suite…
    I had to update some chapter markers in PPro. I then opened Encore and ‘Reverted’ the appropriate asset (which was Dynamic Linked). Looked like it worked, since the length of the asset matched my latest changes; however, the chapter points, which I had modified in PPro did not get carried over into Encore. Encore still has the old chapter point times. Is there a clean way to refresh those chapter points? Probably easier to remove the asset and add it back rather than moving all of the markers.
    I found something similar in the Adobe forums:
    https://forums.adobe.com/thread/440419;jsessionid=79BC895E8E07DF60B0109E011B8D6079.node0?tstart=0
    but it claims that issue is fixed with the latest update (which I have), but I must have a different issue.
    Pauley
    Paul Benson replied 17 years, 1 month ago 2 Members · 2 Replies
  • Joe Bowden
    July 22, 2009 at 5:58 pm
    Duplicate your timeline (for safety), and then delete the asset from it – the chapter points should disappear.
    Drag the DL asset back into the timeline – do you have the latest chapter points?
  • Paul Benson
    July 22, 2009 at 6:22 pm
    Yep, that is the work-around I ended up doing. The first time, though, it decided to crash Encore, but it worked the second time. Had to relink my menu buttons, but I didn’t have that many.
    Pauley
