Activity › Forums › Apple Final Cut Pro › researching motion tracking solutions
  • researching motion tracking solutions
    Posted by James Cude on June 6, 2016 at 7:11 pm
    I’m working on a preso about motion tracking, and I hope you all can offer some expert feedback. Now that we have various solutions for motion tracking in FCPX, I wonder what kinds of things people are tracking, and which tools you choose to do it:
    Do you use Motion’s built-in tracker?
    Do you use a FCPX motion tracking plug-in, and if so, which ones?
    Do you use a separate application outside of FCPX and/or Motion?
    What kind of footage do you track?
    What kind of effects are you making with that tracking data?
    Any other reasons why you use motion tracking in your workflows?
    Thanks for all of your help!
    Jeff Kirkland replied 10 years, 3 months ago 5 Members · 4 Replies
  • Darren Roark
    June 6, 2016 at 8:33 pm
    I eally like Slice-X and Track-X from Coremelt.
    It has Mocha tracking under the hood and a simple GUI, being that I am not a VFX whiz it’s nice to be able to handle a lot of things I’d normally have to farm out. It also saves the trouble of leaving FCP X to go to Motion.
    For a live comedy special the director wanted to remove the exit signs on a moving camera, easy with the object remover in slice-x. Same thing with a camera operator filming offstage, easy to remove on the main camera crane shot.
    Track-X is great for tracking muzzle flashes on machine guns, bullet hits on cars, you name it.
    I think I’ve used it the most for screen replacements, phones, monitors, etc. It’s really handy for when the set decorators buy cheap monitors and they don’t account for the actor clacking away at a keyboard that start to wobble slightly.
  • Patrice Freymond
    June 7, 2016 at 10:44 am
    Do you use Motion’s built-in tracker? – YES
    Do you use a FCPX motion tracking plug-in, and if so, which ones? – SLICE-X
    Do you use a separate application outside of FCPX and/or Motion? – MOCHA 4
    What kind of footage do you track? – MOSTLY HD
    What kind of effects are you making with that tracking data? – ANONYMISING / COLOUR CORRECTION / BEAUTIFYING /TITLING / SCREEN REPLACEMENTS / TRAILS,FIRE, ADDING ELEMENTS ETC.
    Any other reasons why you use motion tracking in your workflows? – STABILISATION
    Patrice Freymond
    Editor  Certified Trainer FCPX
    Post Consultant
    Always learning…
  • Jeremy Garchow
    June 7, 2016 at 6:43 pm
    Do you use Motion’s built-in tracker? No
    Do you use a FCPX motion tracking plug-in, and if so, which ones? SliceX/TrackX
    Do you use a separate application outside of FCPX and/or Motion? Mocha Pro/After Effects/Photoshop
    What kind of footage do you track? HD and now 4K
    What kind of effects are you making with that tracking data? Visual Effects to remove and replace objects (roto/paint/screen replacement/keying)
  • Jeff Kirkland
    June 9, 2016 at 7:09 am
    Do you use Motion’s built-in tracker? Occasionally for simple things
    Do you use a FCPX motion tracking plug-in, and if so, which ones? SliceX & TrackX
    What kind of footage do you track? HD & 4K footage
    What kind of effects are you making with that tracking data? Relighting, beauty work, object removal, screen replacement. stabilisation
    (For some reason I can\’t edit my own posts so apologies in advance for the stupid mistakes and bad English that I can\’t go back and fix)
    Jeff Kirkland | Video Producer & Cinematographer
    Melbourne, Australia | Twitter: @jeffkirkland
