Activity Forums Adobe After Effects Rescaling Shatter Pattern of Bricks
  • Graham Quince
    January 2, 2022 at 1:59 pm
    Seeing as you have a brick pattern, why not try using the Custom option instead of the brick pattern. That way you should be able to use your actual bricks to control the cutout.
