Activity Forums Compression Techniques resampling with same codec does not work
  • resampling with same codec does not work
    Posted by Jacques Koorts on May 21, 2012 at 7:58 pm
    ../bin/ffmpeg -y -i output3.mpg -vcodec mpeg1video -r 15 -b:v 200k -s 128×96 output4.mpg
    ffmpeg version N-38338-g52ae41a Copyright (c) 2000-2012 the FFmpeg developers
    built on Mar 2 2012 13:06:32 with gcc 4.6.1
    configuration: –prefix=/home/hawk/opt –enable-gpl –enable-nonfree –enable-version3 –enable-libopencore-amrnb –enable-libopencore-amrwb –enable-libfaac –enable-libx264 –enable-libmp3lame –enable-static –disable-shared –extra-libs=-static –extra-cflags=–static –disable-ffserver –enable-decoder=png
    libavutil 51. 41.100 / 51. 41.100
    libavcodec 54. 4.100 / 54. 4.100
    libavformat 54. 1.100 / 54. 1.100
    libavdevice 53. 4.100 / 53. 4.100
    libavfilter 2. 62.101 / 2. 62.101
    libswscale 2. 1.100 / 2. 1.100
    libswresample 0. 7.100 / 0. 7.100
    libpostproc 52. 0.100 / 52. 0.100
    [mpeg @ 0x366da40] max_analyze_duration 5000000 reached at 5000000
    Input #0, mpeg, from ‘output3.mpg’:
    Duration: 00:00:49.21, start: 1.000000, bitrate: 1149 kb/s
    Stream #0:0[0x1e0]: Video: mpeg1video, yuv420p, 640×480 [SAR 1:1 DAR 4:3], 104857 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
    Stream #0:1[0x1c0]: Audio: mp2, 22050 Hz, mono, s16, 128 kb/s
    [buffer @ 0x3675280] w:640 h:480 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
    [scale @ 0x3672ee0] w:640 h:480 fmt:yuv420p -> w:128 h:96 fmt:yuv420p flags:0x4
    [mpeg1video @ 0x367c160] MPEG1/2 does not support 15/1 fps
    Output #0, mpeg, to ‘output4.mpg’:
    Stream #0:0: Video: mpeg1video, yuv420p, 128×96 [SAR 1:1 DAR 4:3], q=2-31, 200 kb/s, 90k tbn, 15 tbc
    Stream #0:1: Audio: none, 22050 Hz, mono, s16, 128 kb/s
    Stream mapping:
    Stream #0:0 -> #0:0 (mpeg1video -> mpeg1video)
    Stream #0:1 -> #0:1 (mp2 -> mp2)
    Error while opening encoder for output stream #0:0 – maybe incorrect parameters such as bit_rate, rate, width or height
    Reuben Martin replied 14 years, 3 months ago 2 Members · 1 Reply
  • Reuben Martin
    May 22, 2012 at 5:17 am
    Read your terminal output. It’s telling you why it won’t work.
