Activity Forums Adobe Premiere Pro Rerendering from AE?
  • Rerendering from AE?
    Posted by Sean Tatalovich on February 27, 2009 at 12:35 am
    I have a clip from Premiere I (I captured using AVCHD in Premiere.)
    I brought it from Premiere over to AE did some FX and rendered out. One question is do I still need to do upper field first from AE even though the footage has been captured that way?
    And second of all how do I render out? Animation? Pro Res?
    Sean Tatalovich replied 17 years, 6 months ago 2 Members · 4 Replies
  • Vince Becquiot
    February 27, 2009 at 4:56 pm
    Keep the field order the same. Although some choose to de-interlace in AE, I don’t.
    Render to Animation, Prores is compressed.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Sean Tatalovich
    February 27, 2009 at 6:49 pm
    If I deinterlace will anything be lost? (It is only for desktop viewing?). I compared the pro res and animation and I am telling you a very small difference hardly noticeable.
  • Vince Becquiot
    March 1, 2009 at 6:29 pm
    Yes, de-interlacing to reduce resolution.
    You won’t see a big difference in quality going to Prorez, but keep in mind that your final export is what matter. Because it will likely be highly compressed, any prior loss of quality, such as artifacts and noise created by Prorez will be greatly amplified.
    Your goal is really to keep the same quality throughout the production process.
    Vince Becquiot
    Kaptis Studios
  • Sean Tatalovich
    March 2, 2009 at 1:39 am
    Thanks Vince. Animation takes awhile to render. I should do some tests maybe regarding the quality.
    I know in fcp it captures using pro res. And by rendering out the same from ae it plays in fcp timeline with no rendering.
    I was trying to achieve the same thing
