Activity › Forums › Maxon Cinema 4D › Rerender only one object/texture? (keeping occluding objects)
  • Greg Neumayer
    December 28, 2009 at 11:59 pm
    Update:
    I turned off everything (color, reflection, etc.) from all other materials (except transparency) to achieve what I need. (and added an object buffer)
    If I didn’t need the transparency (I have semi-transparent objects that move in front of my material I’m re-rendering) I could’ve just globally applied a nothing-material to the top level of my Object manager and deleted all texture tags except the material I want to preserve.
    Both methods feel like a hack, since I destroy my file making these changes. Is there a better way?
    I could also just assign an object buffer to my material and re-render, but part of the problem is that 1. I need the re-render (i.e. can’t just fix it in AE) and 2. I’m trying to save time, since the orig render took 2 weeks in-house.
    Antifreeze Design
    https://www.antifreezedesign.com
  • Adam Trachtenberg
    December 29, 2009 at 3:01 pm
    Cinema doesn’t have a material ID buffer, unfortunately. If you had rendered with a color pass and object buffer it could’ve made the job easier. The color pass just gives flat colors, so you can use a color picker to create mattes more easily.
