Activity › Forums › Adobe Premiere Pro › Requirements for migrating to CS6?
  • Requirements for migrating to CS6?
    Posted by Neil Orman on December 28, 2012 at 1:26 pm
    I’m in the process of starting a migration from Adobe Premiere Pro CS4 to CS6, and I had two main questions on the process. Any feedback would be much appreciated.
    -Does it matter if I have projects in mid-stream when I migrate? My boss is encouraging me to finish up any projects in mid-stream before I migrate, but there are some I will certainly continue tweaking into the distant future. Will that be a problem in CS6? Is it backwards compatible to CS4?
    -The second question is about the system requirements. Currently I’m working on a PC running Windows XP with an Intel Xeon CPU, 2.33 GHz, 2.00 GB of RAM. Will that be sufficient for CS6, or do I need a different system? (Right now Premiere Pro CS4 crashes a fair amount, particularly when I’m working on big projects with lots of video.)
    Thank you very much,
    Neil
    Neil Orman replied 13 years, 9 months ago 2 Members · 2 Replies
  • Jeff Pulera
    December 28, 2012 at 3:25 pm
    Hi Neil,
    There should be no problem opening CS4 projects in CS6. That said, it is good practice to try and wrap things up before the update “just in case”, but you ought to be safe. I’ve not had any issues in this area myself.
    Regarding system hardware, if your PC is 3, 4, 5 years old, you may want to seriously consider new hardware. Note that CS6 requires a 64-bit OS, so you’d need to upgrade to Windows 7 Pro 64-bit for instance. Does your hardware support a 64-bit OS? Are there 64-bit drivers available for the motherboard?
    Your RAM is inadequate, even for current config should have been maxed at 4GB with Win XP for better performance. 8GB is a good minimum for CS6, but 16GB is even better (RAM is cheap today).
    Premiere CS6 can benefit from Nvidia graphics card technology to offer hardware acceleration in CS6. Most likely you would need a newer display card to take advantage of the “Mercury Playback GPU Acceleration” features.
    Do you edit HD, or intend to move in that direction? AVCHD and DSLR codecs will bring older hardware to its knees in a hurry, meaning it may not even play back without stuttering badly.
    An Intel Core i7 processor and Nvidia graphics are the basis of a decent CS6 editing experience these days. With SD video for instance, imagine exporting a 2-hour production to MPEG-2 for DVD in 10 minutes. Seriously. Or exporting HD to Blu-ray or YouTube in close to realtime or better.
    You could add Windows 7, more RAM, updated display card, etc. to your system, but it will still be very slow compared to even an entry-level Core i7 system. These have 4 cores running 8 threads, and the entire system architecture is just faster in every way, so it’s more than just the processor. Faster RAM, faster hard drive interface (SATA 6Gb/s), faster data transfer all working together.
    If you are still cutting DV footage only, then you might get away with updating current system and it could work out for you, but not so much for HD.
    Jeff Pulera
    Safe Harbor Computers
  • Neil Orman
    December 28, 2012 at 5:01 pm
    This is a wonderful help Jeff, thanks so much for taking the time. My bosses seem to want to stay away from HD, because of the system requirements, etc., but personally I hope we move in that direction.
