Activity › Forums › Apple Final Cut Pro Legacy › Requirements and Workflow for Multiclip with 8- or 10-bit Uncompressed Footage
  • Requirements and Workflow for Multiclip with 8- or 10-bit Uncompressed Footage
    Posted by Michael Lazar on October 28, 2005 at 2:26 am
    Wondering about the system requirements for editing a two-angle multiclip using 8-bit or 10-bit Uncompressed source clips. Anyone working this way? Seems like the I/O subsystem would need to be pretty hefty – possibly even keeping the source clips on separate arrays.
    I’m also curious to know if one can work by first creating the multiclip using low-res assets, editing and then re-capturing/replacing assets at high-res for final output? Will Media Manager handle this?
    Thanks in advance!
    Michael Lazar
    Michael Lazar replied 20 years, 11 months ago 2 Members · 3 Replies
  • Dan Riley
    October 28, 2005 at 3:15 am
    I’ve used the multicam feature for three 1/2 hour shows now.
    I start out by digitizing at DV level. I make my multiclips
    and do my offline that way. I also used clips that aren’t from
    multicam studio stuff, they are just regular clips.
    Then I uprez to 10 bit uncompressed
    to output to DigiBeta. Media manager works ok as long as:
    -you don’t have speed changes, including reverse.
    -you don’t have many still frames. I say “many” because
    sometimes they come through on the uprez and sometimes
    they don’t and you have to redo them. A pain.
    -you don’t have any nested effects. Media Manager don’t lilke them.
    Dissolve, wipes, DVE effects come through fine too.
    But not if you have added a matt fill. Media manager
    can’t seem to keep track of that. So I’ve stopped doing
    many effects in the offline line. I just uprez sooner.
    As far as the multiclip angles etc., I haven’t had any problem
    with Media Manager picking the correct footage. Make sure
    you check the box that asks if you want to uprez all the
    angles or only the one you used. I only uprez what was used
    in the offline. This box will come up when you doing the
    Media manager process.
    As for loading in 10 bit clips for use in multiclips, it would
    probably be ok for two cameras. Maybe more. I’ve never
    used FCP that way. I use a dual 2.5gig G5 and a 4 drive
    SATA RAID with the Sonnet 4+4 card.
    Dan
  • Dan Riley
    October 28, 2005 at 3:22 am
    Forgot to mention,
    my shows are 4 or 5 camera multicam (simultaneous timecode)
    and I’m capturing at DV for the offline.
    Dan
  • Michael Lazar
    October 28, 2005 at 4:41 am
    Thanks for the info. All good stuff to know.
    Michael Lazar
