Activity Forums Compression Techniques Reproduce Video Parameters
  • Reproduce Video Parameters
    Posted by David Moises paz on January 13, 2011 at 2:12 pm
    Hello, I’m a newbie about ffmpeg and I would like someone could help me. This is my situation:
    I have a Kodak camera and I want to convert home videos from the camera’s format to the cell’s format, this the output info for the cell’s video parameter:
    [shak@olimpus ~]$ ffmpeg -i Desktop/MVI_0093.MP4
    FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
    built on Jan 13 2011 08:27:51 with gcc 4.4.3
    configuration: --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid --enable-x11grab
    libavutil 50.15. 1 / 50.15. 1
    libavcodec 52.72. 2 / 52.72. 2
    libavformat 52.64. 2 / 52.64. 2
    libavdevice 52. 2. 0 / 52. 2. 0
    libswscale 0.11. 0 / 0.11. 0
    libpostproc 51. 2. 0 / 51. 2. 0
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Desktop/MVI_0093.MP4':
    Metadata:
    major_brand : isom
    minor_version : 0
    compatible_brands: mp41isom
    Duration: 00:00:07.60, start: 0.000000, bitrate: 145 kb/s
    Stream #0.0(eng): Video: mpeg4, yuv420p, 176x144 [PAR 1:1 DAR 11:9], 131 kb/s, 11.28 fps, 15 tbr, 15 tbn, 15 tbc
    Stream #0.1(eng): Audio: amrnb, 8000 Hz, 1 channels, flt, 12 kb/s
    At least one output file must be specified
    and this is the output for my camera’s video parameter:
    [shak@olimpus ~]$ ffmpeg -i Desktop/000.MOV
    Seems stream 0 codec frame rate differs from container frame rate: 296899.00 (296899/1) -> 29.69 (296899/10000)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Desktop/000.MOV':
    Metadata:
    comment : EASTMAN KODAK COMPANY KODAK C122 DIGITAL CAMERA
    comment-eng : EASTMAN KODAK COMPANY KODAK C122 DIGITAL CAMERA
    Duration: 00:00:03.80, start: 0.000000, bitrate: 10665 kb/s
    Stream #0.0(eng): Video: mjpeg, yuvj420p, 640x480 [PAR 1:1 DAR 4:3], 10592 kb/s, 29.69 fps, 29.69 tbr, 296899 tbn, 296899 tbc
    Stream #0.1(eng): Audio: pcm_mulaw, 8000 Hz, 1 channels, s16, 64 kb/s
    It is possible to encode from my camera to the cell’s format so I can watch the videos recorded with the camera in the cellphone? If so, please someone could tell me which are the correct arguments to ffmpeg.
    As you could see I have already compiled ffmpeg to support amr codecs.
    Thanks in advance for listen and for this great tool.
    David
    David Moises paz replied 15 years, 7 months ago 2 Members · 2 Replies
  • Michael Rampe
    January 19, 2011 at 10:24 pm
    [David Moises Paz] “It is possible to encode from my camera to the cell’s format so I can watch the videos recorded with the camera in the cellphone? If so, please someone could tell me which are the correct arguments to ffmpeg.”
    What you need to replicate is:
    Stream #0.0(eng): Video: mpeg4, yuv420p, 176×144 [PAR 1:1 DAR 11:9], 131 kb/s, 11.28 fps, 15 tbr, 15 tbn, 15 tbc
    For the video:
    ffmpeg -i inputfile.mov -b 131k -r 15 -s 176×144 output.mp4
    Not too sure about the audio as I haven’t used “amrnb” before. From what I have read, you might need to install the amr libraries and reconfigure and make FFmpeg with this codec enabled.
    Michael
  • David Moises paz
    January 22, 2011 at 1:14 pm
    Hello, thanks you very much, its really works!! only to put it clear for others that could read this post.
    #!/bin/bash
    ffmpeg -y -i $1 -b 131k -r 15 -s 176x144 -acodec libopencore_amrnb -ab 12.2k $1".3gp"
    this is the final script used to achieve the result. Note that fmpeg was already compiled with amr support (allows me to put this: -acodec libopencore_amrnb), I needed to save it as .3gp file since ffmpeg give me some error about .mp4 files regards to container not supporting current library.
    thanks again
    greetings david
