Activity › Forums › Maxon Cinema 4D › Reproduce fresnel falloff curve as in 3Dmax
Darby Edelen replied 12 years ago 4 Members · 14 Replies
Adam Trachtenberg
August 20, 2014 at 6:49 pmYou mean in the material preview? I don’t think you can turn it off if the reflection channel is active. If you could you would have no way of knowing what the changes you were making looked like in the reflection channel.
What I do sometimes when working with transparency/bump/reflection shaders is build the shader in the color channel, where it can be easier to see what you’re doing, and when I’m done I’ll copy it to the intended channel and delete from color.
Jeffrey Levenstone
August 20, 2014 at 6:55 pmHello Adam,
I meant for the boll to look like this https://vimeo.com/102082368
Notice is sphere doesn’t have the reflection of the woods(trees) in it.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Adam Trachtenberg
August 20, 2014 at 8:37 pmThe sphere is showing the reflection of the trees — it’s just not as prominent because the Fresnel settings he’s using are cutting down on the reflection. Also, it looks like he’s using a custom scene for material preview, with the two prominent reflector planes in addition to the trees background.
If you really want to get rid of the trees you can create your own material preview scene. The standard preview scenes are located in your Maxon\Cinema 4D R1x\library\materialpreview folder. I would suggest that you modify one of the existing scenes and save it under a new name. You can put a different HDRI in the Sky Object’s material, or get rid of the sky object altogether. That way you’ll have no background reflections.
Darby Edelen
August 21, 2014 at 3:40 pm[Jeffrey Levenstone] “Are you talking from the point of view of the VrayAnvanced shader (Vray4C4D 1.9)?”
No. Are you asking from the point of view of the Vray Advanced shader? 🙂 That’s important to include in the question.
I have little to no experience with Vray.
Darby Edelen
