Activity Forums Avid Media Composer reposition video channel layer
  • reposition video channel layer
    Posted by Franco Bogino on August 31, 2011 at 1:08 pm
    Hi
    Does anyone know how to reposition individual RGB channels on screen in Avid? I know this can be done in Final Cut Pro, essentially you can treat each colour channel as a video layer and reposition them on screen to give an old tv or bad print look.
    I need to do the opposite. I have a lot of dodgy footage which has the green channel a few pixels out of line with the red and blue channels. The effect is a slight fuzzyness to the picture and a slight green edging to many elements of the image.
    We did a test in Photoshop and then in FCP, and realigning the green helps the image a lot. Unfortunately we are editing in Avid, so we need an Avid solution. I’m sure I used this effect in some music montage ages ago, but I can’t remember for the life of me how I did it. If anyone can fill in the blank it would be greatly appreciated.
    Franco
    Franco Bogino replied 15 years ago 2 Members · 5 Replies
  • Ricky Barrow
    August 31, 2011 at 1:23 pm
    Boris (BCC) has a couple of effects that would do this but it really won’t show up as seperate video layers but you can get the same look as you’re describing. I think BCC comes with your Avid App.
    Ricky
  • Franco Bogino
    August 31, 2011 at 2:06 pm
    Hi Ricky
    I thought there might be something in BCC. Unfortunately I don’t have it installed on my current Avid. Can you remember what the effects are called? I’d like to get our online facility to have a look at it.
    Thanks a lot
    Franco
    London based Avid/ FCP offline editor.
    FCP Online.
  • Ricky Barrow
    August 31, 2011 at 2:17 pm
    BCC Misalignment is the one I am thinking of – it allows align or misalign of RGB
    Ricky
  • Franco Bogino
    September 1, 2011 at 8:32 am
    Cheers, that’s really useful.
    FCP Online.
  • Franco Bogino
    September 6, 2011 at 4:48 pm
    I have used the misalignment plugin and it goes a long way towards fixing the damaged footage. The only snag is that the green channel is not only shifted along the y axis, it appears to be slightly rotated on the z axis.
    This means that using the misalignment plugin I can get one side of the picture to look better, but the other side retains the fault.
    Does anyone know of a way to ROTATE the colour channels individually? If Avid has the capability of seeing and acting on individual channels, as it does with the misalignment tool, there must be a way to apply any process to individual channels.
    How is misalignment processing the footage, and can this be recreated using base avid tools?
    Franco
    FCP Online.
