Activity Forums VEGAS Pro reposition still
  • reposition still
    Posted by Rick Wise on February 21, 2008 at 7:31 pm
    I have shrunk a JPG still to about 1/4 size, using PluginPac 3DLE. I want to place it on the left top side of the frame. But when I slide it left it starts to be cut off well before it reaches the left side. I can’t figure out a solution. I’m sure this is something simple I’m just missing.
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
    Rick Wise replied 18 years, 7 months ago 3 Members · 6 Replies
  • Mike Kujbida
    February 21, 2008 at 7:36 pm
    Open up the Pan/Crop window, right-click and select “Match Output Aspect”.
    It will probably increase in size so you use the Pan/Crop tool to shrink it back down and reposition it.
  • Rick Wise
    February 22, 2008 at 6:41 pm
    Mike,
    That solution is not working. It’s as if there’s a wall on the left side. When I shrink the picture to the correct size, no problem. But when I slide it so it is moving toward the left side of the frame, when I am about 1/3 to 1/4 away from the left edge, the picture starts to disappear as if it is sliding behind a wall. That “wall” is the rectangle outlined in pan/crop. If I grab the handle on the box and slide it left, I just shrink the picture further, but the wall remains at the same relative place.
    There must be something obviously wrong I am doing here. I’m stumped.
    Rick Wise
    Oakland, CA
  • Edward Troxel
    February 22, 2008 at 8:24 pm
    First of all, I’d just use Pan/Crop to resize and position as Mike said and not worry about the 3dLE tool unless there’s some specific reason. Otherwise, use Track Motion to position it.
    Edward Troxel
    JETDV Scripts
  • Rick Wise
    February 22, 2008 at 8:47 pm
    Edward, I am using just pan-crop. Still getting the “wall”. However, thanks for the track motion idea — that does it.
    Rick Wise
    Oakland, CA
  • Edward Troxel
    February 23, 2008 at 1:23 am
    After you open Pan/Crop, you MUST right-click the image and choose “Match Output Aspect”. Then after you resize it, you should be able to resize it and position it anywhere on the screen without “running into a brick wall”.
    Edward Troxel
    JETDV Scripts
  • Rick Wise
    February 23, 2008 at 6:28 pm
    Bingo! That’s it: maintain OUTPUT aspect. My duh. But my duh led me to info about track motion I didn’t know, which offers the option of drop shadow — most useful for the project I am working on.
    Rick Wise
    Oakland, CA
