Activity › Forums › Adobe After Effects › Reposition anchor point to center of frame
  • Reposition anchor point to center of frame
    Posted by Yaya Leone on April 1, 2013 at 3:46 pm
    Hello,
    I am trying to find a script or technique that would allow the repositioning of a layer anchor point, or ideally the anchor points of multiple selected layers, to the center of the composition / frame.
    What I am trying to achieve is to move 3D layers’ Z positioning while maintaining their relative position to the frame.
    I am using an expression that maintains the relative size of layer when changing the Z position, though since I am working with layers of different sizes and in different positions, the layers’ relative XY position moves once the Z position is changing, even though the size remains the same.
    Currently in order to achieve that I am placing horizontal and vertical guides at the center of the frame and using the Pan Behind tool to snap to the center – that keeps the layer in place when I move it through the Z space. As I am working with a large number of layers, it would be great to have a script / expression that will set that for all the layers. Anyone?
    Many thanks,
    Yaya
    http://www.yayayaya.co.uk
    @MrYayayaya
    John Cuevas replied 13 years, 6 months ago 2 Members · 1 Reply
  • John Cuevas
    April 1, 2013 at 4:40 pm
    RepositionAnchorPoint
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
