Activity › Forums › Adobe After Effects › repo alpha?
repo alpha?
Posted by Tom Ma on April 18, 2008 at 8:55 pmIs there an (easy) way to repo only the alpha channel of a layer, seperate from the fill?
preferably an effect that does this?
Tom Ma replied 18 years, 5 months ago 2 Members · 2 Replies -
Brian Berneker
April 18, 2008 at 9:03 pmCreate a new solid just beneath the layer with an alpha channel and set the layer mask to point to the alpha for that layer. It will turn your solid into a cutout.
If you need it to be a B/W mask, you can do the whole thing inside a pre-comp, make the solid white, and create an additional black solid beneath it, so that the transparent areas show through as black.
I’m not sure, but there might even be a simple filter (i.e. levels etc) that lets you show the alpha channel directly with the channel pulldown.
Brian
Tom Ma
April 18, 2008 at 9:09 pmwell, I am trying to make an efficient, easy fx favorite that will do this along with other things to give a certain look.
That would rule out the dup’ing of layers to use as the matte.any effect do this?
