Activity Forums Apple Motion Replicator 3D Face Camera
  • Replicator 3D Face Camera
    Posted by Matt Galuszewski on July 12, 2014 at 12:44 am
    EDIT: Figured it out. Don’t ‘Face Camera’ Select ‘Align Angle’ and rotate cell on X.
    I didn’t know how to delete this post.
    __________
    Am I trying to achieve too much with the 3D, Face Camera options checked in the Replicator or am I going about this the wrong way using the Replicator.
    The image pretty much shows the look I am trying to achieve, that of the man standing around the edge of a circle with reflections from a rectangle positioned at the base of the man symbol.
    My reflection in the floor is also following the ‘face camera’ selection but I would like the reflection to be inverted just like a real reflection.
    Any ideas if this is possible using the Replicator?
    I would also be happy if the men were facing inwards to the centre of the circle. I know, turn off ‘face camera’ but then the men lay flat instead of standing up.
    Many thanks for reading.
    Matt Galuszewski replied 12 years, 2 months ago 2 Members · 2 Replies
  • Robin S. kurz
    July 12, 2014 at 9:37 am
    Why not simply use an “actual” floor and “actual” reflection?
  • Matt Galuszewski
    July 12, 2014 at 12:35 pm
    I read my original post and realised I did a bad job of explaining my setup. The reflections shown in the image were “actual” reflections generated by motion.
    As I said, I found the solution to my problem.
