Activity › Forums › Adobe After Effects › Replicating this masking effect
Posted by Philippe Gosselin on September 18, 2012 at 9:02 pmHi all,
Please take a look at this
https://www.youtube.com/watch?v=7cZH861tZhs
I can’t figure out if the black lines are a mask, a solid or both.
How would you go about to create this effect
Philippe Gosselin replied 13 years, 11 months ago 5 Members · 6 Replies -
Tom Daigon
September 18, 2012 at 9:02 pmBad link.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
John Cuevas
September 18, 2012 at 9:14 pmThere are a few different techniques used to create the black lines. A few look like the edge wipe effect in Avid with borders turned on.
A few places it looks like a black solid or line was placed over the video and then wiped off.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Tudor “ted” jelescu
September 18, 2012 at 9:31 pmThe link works if you just copy and paste in the browser- for some reason it does not if you click on it.
To answer your question, the black lines can be created with masks or shape layers. Most likely the video “rectangles” that animate in the frame to create the composite image have a black border.
If you want the black border around the outside: precomp the image on a black solid, mask the image then copy the mask to the solid. Then use the Mask Expansion in the black solid to give you a black border.Tudor “Ted” Jelescu
Senior VFX Artist -
Vishesh Arora
September 18, 2012 at 9:35 pmMr. Gosselin
These black lines are the combination on mask and solid as you have guessed.
Put a black solid below the footage and mast out the desired shapes. You can then animate the shape paths.
Another way to achieve this.
1. Select your Footage/Image and apply “Stroke” Effect.
2. Select the layer in layer panel, Press Q to highlight the Rectangle Tool. Double click on it. This will create the mask around your image.
3. In Effects panel, Change color to Black and increase Brush Size to say 20%.
4. Choose “On Original Image” in Paint Style.
5. Now do the same procedure for other images and animate them as required.Also to animate stroke as there in video, Keyframe the Start or End Value.
Vishesh Arora
VFX and Motion Graphics ArtistBlog:
https://digieffects.wordpress.comDemo Reel(3D):
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
John Cuevas
September 18, 2012 at 9:40 pmWas going to come back and expand on my answer, but it seems pretty well answered now. The answer is, this technique can be achieved a few different ways.
Philippe Gosselin
September 18, 2012 at 10:17 pmThanks Fellas!
Indeed Vishesh, after a couple of experiments I believe the stroke seems to do the trick.
