Activity Forums DVD Authoring Replacing VOB files in a DVD img
  • Replacing VOB files in a DVD img
    Posted by Ri Stewart on March 6, 2014 at 6:28 pm
    A client of mine recently received the rights back from a large distributor for a very complex multi disc, multi side DVD set.
    I was able to pull a disc image from the individual discs/sides – but I need to replace a few bumpers, warnings, etc.
    I attempted to do this with the same length of file in DVD Studio Pro (Are they ever going to upgrade this?) and while the bumpers show as replaced, when they start to play, they lock up the DVD player.
    This is a nasty hack, but would save thousands in recreation to get it back in distribution. Are there any recommendations the herd may have?
    ri
    bluedot productions
    https://www.bluedotproductions.com
    Daniel Ludwig replied 12 years, 5 months ago 4 Members · 4 Replies
  • Andreas Gumm
    March 6, 2014 at 7:26 pm
    This can be done together with DVD-Reauthor Pro & Scenarist SD.
    DVD-Reauthor Pro de-compiles the disc & creates a Scenarist project file if the disc is according to the spec.
    The assets can be exchanged or removed then in Scenarist.
    I do not see a proper solution together with DVD-Studio Pro since it’s a abstraction layer tool.
    Andreas
  • Ri Stewart
    March 6, 2014 at 10:38 pm
    Thank you for your reply Andreas. I’m looking for authoring houses that use this software now.
    Best
    ri
    bluedot productions
  • Eric Pautsch
    March 7, 2014 at 2:16 am
    I made a nice living for about a year doing this back in the day for distributors with After Edit. Doubt you’ll find anyone here that will do this….and very unlikely you will find a house which will either. This kind of stuff is done by hobbyist now days.
    Id head over to videohelp.com and ask there. Maybe you’ll find someone to help you out
    There are a couple guys on these boards who use After Edit still….maybe they will help out?
  • Daniel Ludwig
    March 7, 2014 at 8:47 pm
    I´m still using DVD Afteredit Mastering Edition, but I´m based in germany.
    maybe you can call Robin or Larry from Rivergate Software, they might be able to giv e you a hand on the project.
    danny
