Activity Forums Apple Final Cut Pro Legacy Replacing timeline sequence footage with same footage in different codec
  • Replacing timeline sequence footage with same footage in different codec
    Posted by Grant Wilber on February 11, 2011 at 2:02 pm
    I started editing a bunch of H.264 footage in Final Cut and am having render issues (getting “codec error). I usually convert it to prores first but didn’t want to deal with it so now its bitting me in the ass
    If I convert the footage is there any way I can get it to replace the clips that are already edited in the sequence? I shot on a DSLR so there is no timecode.
    I also wonder if you could do this because my mac lags when I edit in 1280. Is it possible to edit the whole thing in 720 then somehow replace all that footage with the 1280 footage? Thanks.
    Jeff Greenberg replied 15 years, 7 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    February 13, 2011 at 2:17 pm
    Convert the clips, the whole clips, put them in a folder structure that matches your existing one, label the folder something different. Then, use your existing sequence to media manage – Make Offline, ProRess 422 720 23.98 (or whatever speed). Then RELINK to your ProRes footage.
    Similar method can be used to work at 1080.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
