Replacing stock photo previews and preserving animation
I occasionally work on projects that call for pretty simple position/scale/rotation keyframing of stock photos in AE, and typically will use low-res preview files until the shots are approved by the client. Then, when I go to purchase and replace the previews, the way I do it is option-dragging the purchased images to replace them in the timeline. They are obviously much larger and my keyframes largely have to be redone, or at the very least lightly adjusted for every single image. Is there a better workflow for this that would circumvent that adjustment step after replacing the previews? Thanks, and sorry if this is a stupid question!
