Activity Forums Adobe After Effects Replacing .PSD and .AI files do not work the same way in Adobe After Effects?
  • Replacing .PSD and .AI files do not work the same way in Adobe After Effects?
    Posted by Nikola Tomic on August 9, 2018 at 3:49 am
    Hello to all.
    How can I replace footage in Adobe After Effects? With .PSD files it works all well (CTRL + H and select changed .PSD file with the same number of layers, same size, just small colour corrections…). But when I try to do the same with .AE layered file – it won`t work!?!?
    Please help, I’ve spent more than 6 hours trying to do faster than manually layer by layer change…
    In short:
    1) I create layered character in Illustrator then import in Adobe AfterEffects as: Composition – Retail Layer Sizes – it creates composition and it is all understandable – I easily animate or rig character. But the problem is – when I try to REPLACE FOOTAGE – I can only see – IMPORT AS FOOTAGE while other options like “Composition – Retain Layer Sizes” simply does not exist in “Import As” menu (!?) For example – I created COPY of Character V1 (named V2.ai) file where I changed only colours of all layers and I expect to replace .AI file (as I do with layered .PSD files) and have the same animated character but with different colours?
    What is the trick? I’ve tried all ALT + CLICK possibilities – none of them works. I can ALT + CLICK and replace layer by layer…
    Will “Collecting whole project” to one directory solve the problem? For example – I collect all for output on Desktop directory named “Character 1” directory. Then I clone (Copy & Paste and then rename “Character 1” to “Character 2” desktop directory and import the same .AE file (with the same sub-files including .AI file with changed colours)? If this will work – what might happen if I plan to import two the same named projects into NEW After Effect project and try to have two characters in one .AE project?
    I hope you understand my question… and problem. Is there any solution? Maybe some script or something if this feature is missing?
    Nykk Deetronic
    https://www.youtube.com/djnykk
    Andrew Somers replied 8 years, 1 month ago 3 Members · 5 Replies
  • Andrew Somers
    August 9, 2018 at 9:32 am
    There is not a command that does what you want, BUT:
    You CAN use a HEX editor to modify the file path and file name of the AI file in the AE project. I use the app “0xED”.
    https://www.suavetech.com/0xed/
    NOTES:
    • Do not rename the layers and do not change their order.
    • Always work in a COPY of your AE project — it is very easy to destroy the project so it won’t open.
    • Anchor point positions may not be maintained and need to be re adjusted in some cases.
    Good luck!
    Andrew Somers
    VFX & Title Supervisor
    https://GeneralTitles.com
  • Chris Gomersall
    August 9, 2018 at 5:56 pm
    If I understand you right…
    Import the updated art into your project. Select the layer/pre-comp/comp (whichever) to want to update in the project timeline. Hold down option key and drag updated file from the project window to OVER the selected layer/pre-comp/comp (whichever) in the timeline and release. If it has same size, layers, anchor points it should update it in place.
    Or not. Sorry if I misunderstood the issue.
    ~CG
    Kind regards,
    Chris Gomersall
    gomersall.chris@gmail.com
    817-944-4124
    http://www.vimeo.com/channels/texasvideopro
  • Nikola Tomic
    August 9, 2018 at 11:47 pm
    Thank you very much!
    This is what I did (just in case) and then tried your solution: I first COLLECT to output – FILE 1 and set to Desktop. Then I opened renamed (the same project) to FILE 2, go to File 2 dir and replaced old .AI file with new one where I corrected colours (even a bit of changed shape but in size of old layer – to all layers.
    1 – This way I got – FILE 2 like I wanted, but with THE SAME NAME as in FILE 1 (if you understand).
    2 – THEN I tried your solution: I copy/pasted (made backup) and opened FILE2.aep with right mouse click: EDIT WITH NOTEPAD++
    – FILE2.aep opened in Notepad++ (free and also excellent PC program for correcting html / css without changing source!)
    – Then I find FILE1.ai (CTRL + F) – Notepad++ found 40 FILE1.ai listings in .AI file.
    – Go to tab – REPLACE and entered “Replace FILE1.ai with FILE2.ai” and click SAVE.
    When I opened FILE2.aep from Desktop – IT WORKED!!! Thank you for your suggestion – it would never come to my mind to edit source .aep file ☺
    p.s. Why Adobe do not implement this? It would save many problems (as it works perfectly with .PSD)?
    Thanks again!
    Nykk Deetronic
  • Nikola Tomic
    August 9, 2018 at 11:51 pm
    Yes but it works perfect with cloning Precompositions AND with this new file but I have to manually add layer by layer (drag and then ALT + drop) which is sloooow process because my rig has over 40 layers.
    Replacing (CTRL + H) old PSD file with new .PSD file (where I changed all graphics and leave layers with the same names and more/less the same size) works perfectly but CTRL + H will not allow me to replace .AI layered file… I will be able to manually replace FOOTAGE and select LAYER SIZE and find its name which will lead me to 1-2-3 hours work more than it is automated as expected. 😉
    Nykk Deetronic
  • Andrew Somers
    August 10, 2018 at 12:34 am
    Glad it worked!
    I’m surprised that Notepad++ worked to edit the aep file, as on MacOS I need to use a hex editor for the aep file (not even BBedit works without corruption). Notepad++ must preserve the binary data somehow. Or did you save as .aepx ?
    When I wrote the response yesterday I forgot that you can save a project as XML and easily edit in any text editor.
    And as I look into this, I see that doing it via an XML version is by far the better way to go, as it’s safer and preserves important settings.
    And THEN I just remembered that this is something that is scriptable, and here’s a script that can do it:
    https://aescripts.com/batch-search-n-replace-paths/
    And if you wanted to write a script, here a bit from the scripting guide:
    app.project.item(index).layer(index).replaceSource (newSource, fixExpressions)
    Description:
    Replaces the source for this layer.
    Parameters:
    newSource
    The new source AVItem object.
    fixExpressions
    True to adjust expressions for the new source, false otherwise. Note that this feature can be resource-intensive; if replacing a large amount of footage, do this only at the end of the operation. See also “Project autoFixExpressions() method” on page 115.
    Andrew Somers
