Activity Forums Apple Final Cut Pro Legacy replacing proxies, sequence problem
  • replacing proxies, sequence problem
    Posted by Naomie Ross on March 19, 2011 at 2:04 am
    I made an edit of footage I shot on a 7D. In order to work faster I made half size files of all my clips and edited using that.
    Now I am done and want to replace the proxies with the original clips.
    So I made a new sequence with the settings I needed them to be and then I reconnected the media of the proxies to the original full size files.
    When I copied and pasted the edit from the old sequence into the new one, everything came in HUGE for no apparent reason.
    If I drag a clip from the browser into the sequence, it’s fine. It’s only if I copy and paste the clips from the old sequence.
    Naomie Ross replied 15 years, 6 months ago 1 Member · 1 Reply
  • Naomie Ross
    March 19, 2011 at 3:50 am
    ok I figured it out. For each clip I opened up the motion tab and they were all at 200% scale, so I put it back to 100%. I still don’t know why that happened to begin with, but at least it’s fixed.
