Activity Forums Adobe After Effects Replacing lights from C4d
  • Replacing lights from C4d
    Posted by Brendan Watts on October 29, 2007 at 5:01 am
    G’day all,
    I am in desperate need of some advice. I’m trying to bring in a Cinema 4D file into AE CS3, using lights as reference points from which I can place 2D objects. I’m using the method listed on this website: https://www.studiodaily.com/main/minisites/aftereffects/f/mtutorials/6890.html
    Problem is that when I alt + drag the 2D element over the light to replace it I get the message: “error 26::335 layer does not have a source”. I can’t figure it out!!! the same 2D graphic will come up fine in other AE comps, so its not missing or anything…
    HELP!!! PLEASE!!!
    Kind Regards,
    CB.
    Brendan Watts replied 18 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
