Activity Forums Apple Final Cut Pro Legacy replacing hard drive on MBP
  • replacing hard drive on MBP
    Posted by Trevor Ward on May 29, 2009 at 1:33 pm
    Not sure this is most appropriate forum, but I’m a FCP user and here goes:
    I have a 2 year old MBP with only a 100GB hard drive. How easy is it to install a new, larger hard drive? I’d kind of like more space for capture files. And yes, I already have several external drives including a RAID. But sometimes it’s nice to have everything in one aluminum box.
    I’d want to transfer everything to my new hard drive, i.e. downloaded software, settings, mail, documents, etc.
    -trevor ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    orlando, fl
    Rich Rubasch replied 17 years, 3 months ago 7 Members · 6 Replies
  • Zane Barker
    May 29, 2009 at 2:26 pm
    [Trevor Ward] “I have a 2 year old MBP with only a 100GB hard drive. How easy is it to install a new, larger hard drive? I’d kind of like more space for capture files”
    You get POOR performance when you capture and edit from the same drive as your OS and applications. The internal drive already has plenty to do, running the OS applications etc, piling video on top of that is just not a good idea.
    I recommend getting a small bus powered drive that can be attached. With a bus powdered drive you don’t have to plug it into a wall for power.
    As for how difficult it is, well for some people it is not difficult at all, and for others it may be kinda difficult it all depends on your technical knowledge and experience.
    Keep in mind that doing it yourself technically voids any warranty you may have, so I always recommend having it done by a certified Apple Technician.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Steve Eisen
    May 29, 2009 at 2:27 pm
    You be the judge if you can install a hard drive.
    https://eshop.macsales.com/installvideos/
    I did it myself so I could have more space to ad more apps.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Ed Dooley
    May 29, 2009 at 3:27 pm
    I put a new 200 gig drive in my MBP (pre-unibody model) using the same video. It went very easy except for temporarily losing one small screw when it attached itself to the magnet in the MBP latch. 🙂
    Ed
  • Marcelino Guel
    May 29, 2009 at 3:38 pm
    The video is great and all, but it’s kind of nice to have the option to print something out.
    I too replaced the HD in my MacBook Pro and replaced it with a larger, faster (7200 RPM + more cache), Seagate drive from Best Buy. I just printed the instructions and off I went…
    This website has instructions for pretty much everything, and the nice thing is they are model specific.
    One other piece of advice I have is to make sure you keep all of the screws separated. I basically placed them on a piece of paper and noted what step it was that was associated to their removal (I hope that makes sense).
    https://www.ifixit.com/Guide/Browse/Mac
    Here is a pic of my project:
    Good luck!!
  • Bob O’brien
    May 29, 2009 at 4:12 pm
    I just installed a 500Gb Seagate into my 2.0Ghz MBP. Make sure you have the two tools required… and then just follow the online instructions. The process was not bad at all.
    Bob
    CAMERAS
    Sony EX3 & Sony DXC637/PVV3 Betacam-SP
    PORTABLE EDITING
    *MacBook Pro – 2.33Ghz – 2Gb RAM
    *Matrox MXO / 23″ Cinema Display
    DESKTOP
    *DualG5 2Ghz w/2.5Gb RAM
    *UL4D SCSI Card
    *HMV800 DualMax RAID0
    *AJA IO
    *Sony 2800
    SOFTWARE
    *OSX10.4.11, QT 7.5, FCP 6.0.4, Livetype 2.1.3, Soundtrack Pro 2.0.2, DVDSP4.2.1, Adobe CS3 Prod Suite
  • Rich Rubasch
    May 30, 2009 at 3:06 am
    I installed a new 320 gig drive in my Macbook plus replaced the Optical drive which had also failed due to a child inserting some foreign object!
    I took my original 80 gig drive and put it into a small USB enclosure and use it as a transfer drive.
    Rich Rubasch
    Tilt Media
