Activity Forums Apple Final Cut Pro Legacy replacing green screen color on FCP7?
  • replacing green screen color on FCP7?
    Posted by Raju Bhai on August 6, 2017 at 8:16 pm
    Hello,
    I have a bunch of shots i filmed with the band in front of a green screen for a music video. However for a few of the shots i am not chroma keying any images behind the band because i prefer the way it looks with just them in front of the green screen.
    However i do want to change the color of the green background to say something like white or perhaps even a different color, just so it doesn’t look so obvious that they are in front of a green screen.
    I imagine this should be really easy to do. But for whatever reason, i just can’t figure it out!
    Raju Bhai replied 9 years ago 2 Members · 4 Replies
  • Michael Gissing
    August 6, 2017 at 10:28 pm
    To replace green with any other color you still need to create a key. So chroma key to a white slug or whatever color you want.
  • Raju Bhai
    August 7, 2017 at 12:39 am
    hi!
    Actually I am trying to AVOID USING CHROMA KEY for this. Reason being is that these particular shots won’t chroma key well, so just wondering if there is a way to just select the green background and swap it with a white background for instance without using chroma key. Is that possible?
  • Michael Gissing
    August 7, 2017 at 12:51 am
    A key is a key.
  • Raju Bhai
    August 25, 2017 at 8:59 pm
    OK, but couldn’t there be another alternative to chomakeying? i.e., a “replace color” feature whereby I select the green background with the dropper tool, and only that specific range of green color will be inputed by the computer and then from there I just select any other color to replace it with?
