Activity Forums Adobe After Effects replacing footage in timeline
  • replacing footage in timeline
    Posted by Aeprowannabe on November 16, 2006 at 5:57 pm
    Hello,
    I’m trying to replace a layer/footage in my timeline with another footage. I’ve been trying the following insturction from the help section but it doesn not seem to work for me.
    To replace the source footage of one or more layers:
    In a Timeline window, select the layer or layers to be replaced.
    Hold down Alt (Windows) or Option (Mac OS) as you drag a footage item or composition from the Project window to either of the following places containing the selected layers: the Composition window or the Timeline window.
    Release the mouse and then the keyboard key.
    ___
    when i drag and drop, it just places the new layer on top of or infront of the old layer instead of replacing it. Am i missing something? I’m working on a MAC/AE6.5.
    thanks!
    Frank Mcpolin replied 13 years, 6 months ago 4 Members · 6 Replies
  • Broken
    November 16, 2006 at 6:50 pm
    In the comp timeline, highlight the layer you want to replace.
    In the project window, find the replacement footage. Select it and realease the mouse button. Hold down the option key and drag that footage OVER the layer to be replaced. Release! You’re done!
    Still not right? Practice, practice, practice.
    Dave LaRonde
    Sr. Promotion Producer
    KCRG-TV
  • Aeprowannabe
    November 16, 2006 at 7:02 pm
    When ever i option/drag the footage to the timeline over the layer i want to replace…it keep going on top or below that layer. its like the option button doesn’t work…
  • Todd Gillespie
    November 16, 2006 at 7:33 pm
    you need to highlight (click) the layer that you’re replacing in the timeline, then option/drag.
    Todd at UCSB
    Television Production
  • Aeprowannabe
    November 16, 2006 at 7:43 pm
    yes.
    i highlight the layer, than option/drag the new footage into the timeline. it give me the line either above or below the layer that i have highlighted as if I was doing the same thing without holding down the Option key….this is really driving me crazy!
    thanks for helping though!
  • Frank Mcpolin
    November 6, 2012 at 5:29 pm
    I just struggled with this in After Effects 6 too – it looks to be because you need to hold down the Alt key, not the command key.
  • Frank Mcpolin
    November 6, 2012 at 5:31 pm
    I just struggled with this in After Effects 6 (Mac) too. It seems to be because you ned to hold down the Alt key, not the command key.
