Activity Forums Adobe After Effects Replacing Footage in COMP
  • Replacing Footage in COMP
    Posted by Michael Gagliano on March 5, 2006 at 4:38 am
    We have a master comp with a lot of fx and keyframes, is there any way to replace the current footage in the comp with a new section of footage i.e drag with a keypress etc. Placeholder will not work as if I am correct it will replace all the footage in all the comps.
    Michael Gagliano replied 20 years, 6 months ago 3 Members · 3 Replies
  • Olav Nossum
    March 5, 2006 at 5:14 am
    First select the footage you want to replace in the timeline, then hold down “alt” and drag the new footage on top of the old.
  • John Dickinson
    March 5, 2006 at 5:44 am
    If you don’t want to drag and drop you can use the keyboard shortcut: COMMAND OPTION / (mac) or CONTROL ALT / (pc).
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Michael Gagliano
    March 5, 2006 at 7:15 am
    thanks will give it a try
