Activity › Forums › Apple Final Cut Pro Legacy › Replacing footage already edited in FCP with different codec footage, i.e. H264 with ProRes
Rafael Amador replied 14 years, 5 months ago 4 Members · 13 Replies
Rafael Amador
March 28, 2012 at 4:03 pm[Sai Kelly] “On a side note, has anyone used the Atomos Samurai or Ninja? I get the impression that this would allow people to avoid all the transcoding hassle in the first place.”
that works OK with any camera with a clean HDMI/SDI out put.
If you are using a DSLR, Canon and Lumix don’t have it.
Nikon claims to have an “uncompressed 8b” signal, but still have to be proved and tested.
rafael -
Sai Kelly
March 28, 2012 at 4:18 pmAh bum, what do you mean by clean output? just uncompressed?
Do you know of anything out there that can bypass the DSLR’s camera compression, for the 5DMKII?
Cheers Raph
S
(Sorry moderators ill stop this line of questioning after this, as we’re moving away into another topic.)
Rafael Amador
March 29, 2012 at 2:18 am[Sai Kelly] “Ah bum, what do you mean by clean output? just uncompressed?
Do you know of anything out there that can bypass the DSLR’s camera compression, for the 5DMKII?”
The picture quality is downgraded and the time-base is messed up with an strange pull-down.
Nobody have been able to make the 5D to put out a signal worth to record.
There are tons of literature about on internet.
RAFAEL
