Activity Forums Apple Final Cut Pro Replacing clip with Project or compound clip
  • Replacing clip with Project or compound clip
    Posted by Juan Lesta on July 31, 2016 at 12:11 pm
    Hi!
    I’m trying to resolve this situation:
    An editor (1) edited an interview and sent rendered it as a clip it to the editor 2
    Editor 2 re-edited the interview with more clips and cuts, and sent it to me.
    Now I have a project with a lot of references to the first edition which is a clip, but I have the project referenced to this clip.
    The issue is: there is any way to replace the references to the clip with the project (or compound clip) which is referenced to?
    Thanks a lot
    Juan Lesta replied 10 years, 1 month ago 2 Members · 2 Replies
  • Jeff Kirkland
    August 1, 2016 at 12:53 am
    I’m not sure I 100% follow what you’re needing to do but no, you can’t relink or change the clip the edit references to.
    What’s the issue you’re trying to solve?
    (For some reason I can\’t edit my own posts so apologies in advance for the stupid mistakes and bad English that I can\’t go back and fix)
    Jeff Kirkland | Video Producer & Cinematographer
    Melbourne, Australia | Twitter: @jeffkirkland
  • Juan Lesta
    August 2, 2016 at 7:36 pm
    Hi, and thanks.
    I need to replace a clip with edited content with the project it comes from (and was done from).
    I thinks its no possible 🙁
