Activity Forums Adobe Premiere Pro replacing clip with after effects composition
  • replacing clip with after effects composition
    Posted by Alex Rod on May 23, 2013 at 3:48 pm
    I had a timeline with 6 clips on it and replaced all the clips with an after effects composition. Now the timeline shows everything as one clip. Is there a way to see the individual clips again in premiere pro?
    David Ghast replied 13 years, 3 months ago 4 Members · 3 Replies
  • Gabriel Sanchez
    May 24, 2013 at 12:48 pm
    Go a step back in the history pannel, before you replaced this clips with the AE comp. Next time, duplicate the sequence before dynamic linking clips from PPro to AE to preserve the original sequence with individual clips on it. To recover your AE comp, i´ll save the AE proyect with other name, and just drag and drop it from AE proyect pannel to PPro proyect pannel to use it as a simple clip.
    Regards
  • Kris Merkel
    May 24, 2013 at 1:22 pm
    Once you use the DynamicLink with replace with AE clips, all the editing of those clips will be done in AE and you can view them in the AE timeline. That is how Dynamic link works.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • David Ghast
    May 24, 2013 at 6:37 pm
    Its a one way process unfortunately, its best not to use that technique until you have to, or import a dummy file and replace that with the comp, then switch out your placeholder video file with the comp as needed.
