Activity Forums Apple Final Cut Pro replacing audio on multicam clip
  • replacing audio on multicam clip
    Posted by Mark Mcfarlane on August 6, 2014 at 7:55 pm
    I have a multi cam clip with three angles, one is an audio-only mix down from a 24-track recording, the other two are are from two different video cameras.
    I have successfully created a project and setup transitions between the 2 camera, and selected the multi-track mix down as the only audio that runs the entire length of the project.
    fter auditioning on various devices, Ive decided the bass os a tad too heavy.
    Is there a way to either
    1) replace the entire audio track inside the multicam clip with a new mix, or
    2) Apply the same EQ to all clips in the multicam clip
    If I select all clips within the multicam clip the ability to create a custom EQ seems to disappear.
    My reference is #1 above, to simply replace the angle within the multicam clip that is audio only with an entirely new mix, although that may be problematic (resyncing).
    I guess another option is to just drop in the remixed audio track, manual sync it, and turn off the audio in the multicam clip.
    I hope this is clear.
    Cheers,
    Mark
    Mark McFarlane
    Video Novice
    Mark Mcfarlane replied 12 years, 1 month ago 2 Members · 2 Replies
  • Andy Neil
    August 6, 2014 at 9:58 pm
    You can do both. For number one, import your new mix of audio. Open your multi-clip. Create a new angle and drop the new audio into that angle. Sync with the rest of your footage and then set that as the audio monitoring angle.
    For number two, open up the multi-clip and apply EQ to the audio angle. The changes will ripple down to the edits in the timeline.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Mark Mcfarlane
    August 7, 2014 at 9:43 am
    Thanks Andy, I’ll give these a try tonight.
    Mark McFarlane
    Video Novice
