Activity Forums Adobe After Effects Replacing audio in video
  • Replacing audio in video
    Posted by Graham Macfarlane on January 2, 2011 at 10:36 am
    Could anyone suggest the best software to use for replacing the audio track in a video.
    I would like to avoid having to re-encode the video if possible.
    Normally I use Vdub for this process however the video I have is a MOV file using the Animation codec. The audio track in the video is uncompressed I have a WAV file of equal length ready to replace it.
    * Vdub wont load the MOV file.
    * Mediacoder doesn’t appear to have an option to replace audio
    * I don’t think AE or premiere can do this without re-encoding the video track (I hope I’m wrong)
    Any ideas welcome and Happy New Year to all!
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
    Butch Golden replied 15 years, 4 months ago 4 Members · 4 Replies
  • Tudor “ted” jelescu
    January 2, 2011 at 11:20 am
    I may be wrong, but I think that if you have an animation mov and you just replace the audio in AE and render out agai to Animation at 100% you will not re-compress the video but just replace the audio… Todd?!?
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
  • Walter Soyka
    January 3, 2011 at 1:36 am
    [Tudor "Ted" Jelescu] “If you have an animation mov and you just replace the audio in AE and render out agai to Animation at 100% you will not re-compress the video but just replace the audio”
    Technically, this would involve decompressing then recompressing the video, but since animation at 100% is mathematically lossless, there’s no generational loss.
    This is very fast to do with Quicktime Player Pro.
    Open the new audio track in Quicktime Player Pro.
    • Edit > Select All
    • Edit > Copy
    Open the animation movie in Quicktime Player Pro.
    • Window > Show properties.
    • Select the audio track, then click the delete button
    • Edit > Add to movie
    • File > Save As… to a new file (to force Quicktime to flatten the movie).
    Walter Soyka
  • Graham Macfarlane
    January 3, 2011 at 1:52 pm
    Thanks guys for your ideas.
    I don’t have QT pro but I do have access to Adobe audition and after a few attempts managed to get a decent result from it.
    The original video was using the animation codec at 75% quality so rendering via AE again at animation 100% would have maintained quality for sure but also increased file size (already standing at 5.6GB)
    I’m amazed that AE/premiere/Adobe Media Encoder do not have an obvious facility to strip and replace audio tracks in video.
    Cheers
    Graham Macfarlane
    London UK
  • Butch Golden
    January 3, 2011 at 4:08 pm
    I may be way off here (wouldn’t be the first time) but I have replaced audio in Pinnacle and Avid NLE’s for a long time simply by muting the original audio track, add an additional audio track, import the desired audio and place it on that track – then adjust to taste. Although I haven’t had a need to try it in Premiere, especially with a QT .mov it should be possible there as well.
    QT Pro (for $35 US) is the cat’s meow for a huge amount of conversion and edit functions. Worth every bit of the cost many times over.
    HTH
