Activity Forums Adobe After Effects Replacing audio in a QT movie – can it be done without degrading the video?
  • Replacing audio in a QT movie – can it be done without degrading the video?
    Posted by Joakim Dalfors on July 11, 2006 at 6:10 pm
    Hello?
    I have made some compositions in AE that I rendered out in QuickTime PhotoJPG format.
    For some reason I would like to replace the audio stream in theese clips without degrading the video (I.e. I do not want to decode and rerender the clips). Is there a way to do this with AE, PPro or QT?
    best regards
    Joakim
    Stefan Tapper replied 20 years, 1 month ago 3 Members · 5 Replies
  • Barend Onneweer
    July 11, 2006 at 6:34 pm
    I’ve done it in Audition, but that’s not your question.
    It can’t be done in AE, and I’m not 100% sure about Premiere. Importing DV into a DV timeline and rendering to DV doesn’t cause recompression (unless effects or processing are added). But in your case I think you’ll see recompression.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Joakim Dalfors
    July 11, 2006 at 6:51 pm
    Hello Barend and thanks for quick response.
    As you say, using the DV format will not give rise to recompression but I am convinced that photoJPG will.
    But you mentioned audition. I do have acess to that program and if I understand you correct, it is possible in Audition without rerendering of the video?
    best regards
    Joakim
  • Joakim Dalfors
    July 11, 2006 at 6:57 pm
    Hello Dave!
    And thanks to you to for quick response.
    I do have QT pro but I have almost now experience in using it except as a player. And yes the only thing I want do do is replace the audio with a clip of the same duration.
    I
  • Joakim Dalfors
    July 11, 2006 at 7:10 pm
    Hello again.
    I tried Audition and it worked exactly as I wanted.
    Many thanks for the good advise!
    Joakim
  • Stefan Tapper
    July 11, 2006 at 7:40 pm
    Hi jodal,
    you can do it in audition, but with no appropiate compression(i think) only uncompressed.
    If you have your audo exported, open it with quick choose>export>qt movie>unchek video>check audio and export it to AAC for example. AAC gives good quality at low bitrates, For web-audience I would choose ~160kbit/s for purposes 320.
    When the movie is exported open it with qt choose edit>mark all>copy- Open your rendered movie choose>edit>add to movie. If your movie contains already audio, choose window>movie proberties and uncheck or delete the old audio track.
    When you just save your movie now, qt will link the audio to the original audio file/movie. If you want to save the audiostream within your original movie choose>file>save as standalone movie…
    PS: I use a german qt version and translated all the dialogs badly. I’m sure they are named different in your version. But you should find your way easily.
    Stefan
