Activity Forums Adobe Premiere Pro Replacing audio after scenes edited. Workflow suggestion?
  • Replacing audio after scenes edited. Workflow suggestion?
    Posted by Brian Sarfatty on May 11, 2016 at 4:03 pm
    So here’s the situation. Cameras had a mix down of lavs and booms. There were 8-track wav files recorded separately with all the mics sorted separately.
    For a variety of reasons, scenes were edited with the camera audio, and I am not going back and swapping in the 8-track wav files.
    Normally I’d do this sort of syncing first, then edit. So doing this the other way around is proving to be a bit challenging. Looking for suggestions.
    Right now my workflow has been to match frame the camera, copy the timecode. Use “merge clip” with the source clip and audio in bin. Paste the timecode on the merged clip in source window, then re-edit the audio. Tedious, and error prone.
    Wondering if there’s some better workflow out there someone can recommend? Or some way to automate this for footage already in t?
    Alex Udell replied 10 years, 4 months ago 2 Members · 2 Replies
