Activity Forums Adobe After Effects Expressions Replacing a string of text from a text file (with a small twist)
  • Replacing a string of text from a text file (with a small twist)
    Posted by David Newman on October 2, 2019 at 10:29 pm
    Hi there,
    I have an expression on my text layer which evaluates a variable in a text file to get a string:
    $.evalFile(“/D:/main.txt”);
    eval(thisLayer.name)
    And inside the main.txt:
    string1 = “Hello world”
    And finally the text layer name is appropriately called “string1” so that the string is evaulated correctly and the text on screen is “Hello world”.
    What I really want to do is to have more than one strings in my text file, like this:
    string2 = “Hello Mars”
    string3 = “Hello Pluto”
    text1 = “Human”
    text2 = “Martian”
    text3 = “Plutonian”
    And I want to define multiple strings by having two text layers called “string” and “text” and having a null object above simply called 1, 2 or 3 to change the text.
    And have the expression as:
    eval(thisLayer.name+(index-1))
    But it doesn’t work. Hope this vaguely makes sense. I’ve managed to achieve the effect adding the layer name to a slider value, but I’d rather do it with another layer. Thanks.
    David Newman replied 6 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 2, 2019 at 11:35 pm
    I think you’re maybe making it more complicated than it needs to be. If you use this as your text file:
    text1 = “Human”
    text2 = “Martian”
    text3 = “Plutonian”
    Then once you do this:
    those six variables (string1, string2, etc) should exist in the expression.
    So this:
    string2
    Should give you “Hello Mars”, so I wouldn’t think you’d need to do an eval() to select which string gets displayed.
    It might be even better to do something like this with your text file:
    strings = [“Hello world”, “Hello Mars”, “Hello Pluto”];
    texts = [“Human”, “Martian”, “Plutonian”];
    Then an expression like this:
    $.evalFile("/D:/main.txt");
    idx = 2;
    strings[idx] + "\r" + texts[idx]
    Would give you:
    Hello Pluto
    Plutonian
    Then you just need a clever way to select idx…
    Dan
  • David Newman
    October 3, 2019 at 3:44 pm
    Thanks for your reply, Dan.
    Lots of useful tips in there!
